4 members (jmoore, Jon G, 51sub, 1 invisible),
104
Mod | | | Forums66 Topics128,288 Posts1,058,574 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Hi all I have a friend that just picked up a 1954 3600 3/4 ton longbed. He is having trouble finding brake lines pre-bent for it. Where is a good source for this particular model? Seems like it's hard to find parts.
Thanks!
1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Inline Tube $145 OEM $170 Stainless Steel 3/4 ton 1954 | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | I bent my own from pre-flared sections from my FLAPS.
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Hi all, Thank you. I will let him know. Tclederman, I took a look at inlinetube, looks like they only have them for short-beds. Also looking at www.classictube.com
1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Thanks for the correction, UnklRod. It looks like 1952 is the last year they have lines for an Advance-Design 3/4 ton.
They will make up lines at the same cost if someone wants to send them an a set as a template. They made/matched the fuel line for my 54 Suburban and it fits perfectly.
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Tim -
Are the in/out ports of the fuel pump on your '54 parallel to the block, or are they angled at 20deg to the block? InLine tube, via Chevs of the 40's, says they do not have a template for lines that connect at the 20deg angle. Mine ports are at 20deg, as are the ports on the '52-'54 pump in the Chevrolet Master Parts Catalog.
('54 3100 235 Rochester B)
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Lonnie, Sorry about the delay in responding. I think that my original fuel pump on a 54 235 truck engine had input/output ports that were about parallel to the block. However, my 235 is gone and I think my 1960 261 fuel pump has lines at different angles. I am looking for old pictures. Sorry, | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Tim -
Thanks, I ordered an InLine Tube pump-to-carb fuel line from Chevs of the 40's. It was bent for a pump that had ports parallel to the engine block. The ports on my pump are at an angle to the block. InLine does not have a template for angled pumps. Since then, I bent a line with help from fellow "Bolters".
By the way, the InLine Tube line looked good - it just didn't work with my pump.
I appologize for highjacking the thread.
