0 members (),
139
Mod | | | Forums66 Topics128,167 Posts1,057,021 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 112 | I guess over the many years of the hood on my 46 panel being flung back and letting it rest on the oppisite side it now seems to have permanet sprung look to it near the front when closed...Does anyone have a solution as to bring the lines back together....
1946 chevy 1/2 ton panel 1937 ford coupe | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | Have the same problem with my '40. I'll be interested in a fix also!! I figured a good body man (and that is Not Me)could fix/straighten/align it. Anybody with experience out there??
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Mar 2008 Posts: 374 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 374 | Casey, I'm not sure about the fix but your little '40 is 'Money'!  | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | Thanks, Big Tee. Your truck is sweet. I know it's off topic, but are those hood props original or ???? I need some!!!  .
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Mine has sprung a little as well. Something else to look out for is end hinge pin developing stress cracking where it sits on firewall. Mine broke last year - was able to have bodyguy weld for me, otherwise new hinge bar req'd. | | |
