3 members (NJC, Hotrod Lincoln, DoubleB), 55 guests, and 0 robots.
Topics128,090
Posts1,056,024
Members48,432
#749149 05/23/2011 3:20 PM
1 Offline
My 1936 high cab 1/2 ton that i am working on has no shocks. Was this an option or are they just missing? If i do need them , does sum one have a picture on how they mount front and rear.Thank you for any help . Tom
1936chevy #749170 05/23/2011 4:36 PM
Y
yar Offline
Y Offline
Tom, I have a restored high cab '36 also. Somewhere I have a list of options and I think the shocks are listed. The same shocks fit '36-'49. I can look for that list if you like.
I can also take pictures of the shocks and their links to the axles but I have no computer skills and I don't know how to post pictures here. I can email them to you. My email is [email protected].
I also recently converted my '36 from 4.11 to 3.55 gears using only OEM Chevy parts, no expensive aftermarket stuff, if that interests you.
Ray
yar #749191 05/23/2011 6:23 PM
I am rebuilding a 38 Master and it has single acting shocks. I found a place called Chassis Engineering that makes a bolt on kit with regular shocks, for the front. I bought the kit and it was really reasonable. Chassis Engineering I think they list the kit for the car but the truck may be similar. You may want to have a look at their web page.
1951 1 Ton Completed
truckernix #749251 05/23/2011 10:27 PM
Ex Hall Monitor
Ex Hall Monitor
Not a bad price. I use the '39 straight axle shock mounts to convert mine. Either way requires a bit of fab because the frame isn't drilled for the tube shock mounts (upper).
Tiny #749383 05/24/2011 10:54 AM
Just finished mounting shocks on my 1936 GMC low cab. Email me and I can send you pictures.
1936 GMC T-14 1/2-Ton Pickup
dunfire #749544 05/25/2011 1:36 AM
1 Offline
please send me your email address. Thanks.
1936chevy #749642 05/25/2011 1:41 PM
36,
just click on his name, select profile and you will have his Email address.
Y
yar Offline
Y Offline
Tom, do you still want the photos of the OEM shocks and the accessory list?
Ray
yar #749809 05/26/2011 2:01 AM
Please do your private messages by PM.
