1 members (Materman),
115
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 100 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 100 | re: 1964 C-10
Gas gauge reads correct level of gas in tank when ignition switch is on, but when the ignition switch is turned OFF, the gauge needle goes to "F". Shouldn't it stay at the last gas level or to "E"? | | | | | Joined: Jan 2011 Posts: 138 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 138 | My 57 gauge falls to F when held upside down (E when in the panel regularly), thats just the way the weighted pendulums fall, maybe yours just does that...
I'd say leave it...
Alex 57' 3100 (The Bondo Bandit) Bad rust and worse wiring, but so much fun.
