| | | Forums66 Topics128,088 Posts1,055,993 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | Okay here we go again, another stupid question.
I did remove the oil pan to be able to clean and replace the old gaskets.
In the bottom of the oil pan I found a short spring in 2 pieces. I thought it was the valve spring in the pump. But when I check now, the retainer pin is still in there.
Can the spring in any possible way come out from the inside ? Don't think so... I hope it is a leftover from someones job before.
Anyone has another idea? The spring is the diameter and length, so I think it's that kind of spring.
/Ulf My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | The spring probably fell in and no one thought it worth the trouble of removing it. If everything is working, don't worry about it. | | |
