7 members (Gdads51, Otto Skorzeny, Wally / Montana, LuckyLee, MickeyP, TUTS 59, kades51),
72
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,051 Posts1,055,710 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | Members: I'm putting my Intake manifold back on after cleaning motor up...I'm also putting on some headers...What do I torque the bolts to that hold them on? Thanks..also, should I put on my new carb on before or after install ? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | 15-20 for the outer 4 bolts, 25-30 for the 2 next to the heat riser. I also like to remove the 2 guide pins at te very outer ends of the exhaust manifold and replace them with bolts for better sealing. I torque them to the same 15-20 ft/lbs as the others. Carb can be installed on the manifold before or after, might be easier to hadle the manifold with it off, though.
Bill Burmeister | | |
