| | | Forums66 Topics128,129 Posts1,056,693 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#74860 03/15/2007 5:03 AM | Joined: Dec 2006 Posts: 27 Apprentice | | Apprentice Joined: Dec 2006 Posts: 27 | Back again for more advice. Before I install the oil pan on my '54 235 I would like to tap the 2 bolt holes on the lower timeing cover and install studs. Can someone please tell me what the best tap size to use as it seems the tap will also run through the backing plate. Also, what is the function of the other 2 holes in the block above the lower timeing cover bolts? They are drilled at a 45 degree angle. Are these vents or ports to oil the timing gears? If thats the case is it normal for the timing cover to fill up with a small amount of oil? Thanks! | | |
#74861 03/15/2007 5:20 AM | Joined: Feb 2006 Posts: 112 Member | | Member Joined: Feb 2006 Posts: 112 | those are oil ports...the drill size etc. is in tech tips i believe, or try the search feature..i did mine, real simple but don't remember size.. | | |
#74862 03/15/2007 5:24 AM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Metrinut, I believe the holes should tap 3/8" N.C. , the two holes at an angle are the oil drain back holes from the timing cover area, hope that helps. | | |
#74863 03/15/2007 11:29 AM | Joined: Dec 2006 Posts: 27 Apprentice | | Apprentice Joined: Dec 2006 Posts: 27 | Thank you. It does help as the deeper I get into this old truck the more questions I have. Although I am still baffled on the drain back holes since they are well above the bottom of the timing cover. Does the timing cover hold a bit of oil? | | |
#74864 03/15/2007 1:10 PM | Joined: Jan 2007 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 79 | Metricnut, you are correct, the timing cover does hold a small amount of oil. I believe the intent was to give the timing chain and gears better lubrication both on startup and while running.
1949 "Heinz 57"
#74865 03/15/2007 2:51 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Metricnut,
Your engine should have a nozzle above the timing gears that squirts oil onto them. The angled holes you are looking at in the bottom allow this oil to drain back to the crankcase.
Stuart | | |
#74866 03/15/2007 7:44 PM | Joined: Dec 2006 Posts: 27 Apprentice | | Apprentice Joined: Dec 2006 Posts: 27 | Ahhh! that explains it. Their is a nozzle above the timing gear but it was pinched off by the engine builder. Should the nozzle be fully or partly opened? | | |
#74867 03/15/2007 8:04 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Metricnut,
The nozzle is pinched off.....by the factory! It was the best way to seal the end. The orifice is near the end pointing down. I think the book says it can be up to 30° to the left, or pointing more toward the cam gear.
Stuart | | |
