7 members (JW51, Gdads51, 52Carl, TrknGMC, Leo, texas46, 1 invisible),
193
Mod | | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | So my engine did not have this, and while ordering my motor mounts, noticed them for sale. I bought the heat valve spring as well as the anti-rattle spring. My question is do they both go onto the end of the flapper, or is the anti-rattle spring even needed. i could only get one spring on, so i only replaced one. A photo would be awesome. or any advice. The shop manual wasn't much help. I may be overthinking a very simple item, but just wanted to double check. | | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | I just sent you a couple of pics , they are a bit big , I hope your email can handle it ok. Regards. | | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | Thanks. After I went back out, I looked a second time, and found a piece of the old broken spring that was more or less fused to the shaft. a little filing broke its tether and both are now installed and functioning. Thanks | | | | | Joined: Feb 2010 Posts: 33 New Guy | | New Guy Joined: Feb 2010 Posts: 33 | I checked the heat valve on my 65 283 after reading your disscusion, it is free and manually flips up and down, but it stays down even when its hot (need new springs I guess). Does this mean that the exhaust air continually heats the intake? Can this cause overheating? Also, I have noticed that my passenger side tail pipe (dual exhaust) is always cooler than my driver side tail pipe. Does that have something to do whith the heat spring valve being on the passenger side?
Bullhead | | |
