3 members (46 Texaco, Shade Baby, 1 invisible),
345
Mod | | | Forums66 Topics128,162 Posts1,057,056 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Tried to drive the truck again last Friday and another new problem popped up. The offset rod which has a threaded end that goes through the clutch fork - it has two 3/4 inch nuts on it which you use to adjust the clutch - pulls the top end of the "L" rod over to the left so far that when the clutch pedal is depressed, it forces the entire clutch pedal off of the axis the clutch pedal travels on. It actually pushed the large hair pin off the end of the axis point on which it travels as you push the clutch in and out. The link between the bottom of the clutch pedal and the off set rod is linked together with a few links of chain and the chain does not ride in a straight line but is pushed over to the left as the pedal is depressed and as it moves, it pushes the clutch right off the end of pivot. I finally moved the chain back from the factory spot on the "L" shaped rod, more to be right and in line with the bottom of the clutch pedal, where the chain hooks on, to get it to work. It works fine there, but, of course, that's not where it's supposed to be. Has anybody else had this problem? Does anyone know if the "L" rods vary in size or shape from year to year or model to model? Any suggestions are appreciated!
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Joe, I searched for an image of a '37 clutch system as you describe and came up empty. So, I'm wondering if you can upgrade that assembly to a '47 to '59 system using the parts on the attached Classic Parts page. That would be the offset rod and linkage rod. http://www.classicparts.com/Clutch-Parts/products/429/2/0I have three L shaped clutch offset release rods from various years and they are all the same.
Drew
| | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I found nothing about any kind of link when I checked the parts book. Kind of odd - I'm not real sure what kind of clutch fork to clutch pedal a 37 had. I know what mine has, but apparently it's not correct.
