4 members (Southerntruck, Phak1, DaveV, 2-Ton), 90 guests, and 2 robots.
Topics128,035
Posts1,055,566
#747716 05/17/2011 2:27 PM
I can not find the cfm for my holley 2bl. I have checked all the sites suggested on my search engine, including the holley site with the pdf listing. The list number is R 8053 the date is 0963. It came from the stock room of a part store that changed hands and had been on the shelf for many, many years. This may be the wrong forum, anyway, thanks.
Bullheadjoe #747723 05/17/2011 2:45 PM
Can you link us to a pic.
gotgasd #747778 05/17/2011 6:24 PM
gotgased,
I will do it later this afternoon or evening and I hope you can help me out. Every few months or so I try again to get the information, but so far it does not exist. That's par for the course for me it seems. I must have logged off just before you responded this morning. Thank you.
Bullhead
Bullheadjoe #747951 05/18/2011 6:49 AM
Is it a 3 bolt or 4 bolt mount? If its a 3 bolt, it probably fits a Ford Y-Block and is about 175 CFM.
crenwelge #748250 05/19/2011 3:06 PM
I am having technical problems with posting the pictures. I will try again when I have about 2 hours of free time.
It is a 4 bolt, I have it on my 283. The top of the float cover is copper colored (not copper) is this common? There is no hole to check the fuel level.
Bullheadjoe #748533 05/20/2011 3:33 PM
O.K. heres the deal. I need to have a URL or something to get these pictures posted so that you guys can help me out on finding out the cfm of my holley 2bl. I do not have a facebook page, u-tube entry or any other thing of this nature, because I swore to myself that I would not get caught up into the whole internet deal. I guess it is time. I'll see what I can do to get started. By the way, the carb came in a holley box with appropiate gaskets and extra linkage for hot air chokes.
Bullhead
Bullheadjoe #748613 05/20/2011 11:22 PM
Open a photobucket account. It's free. There's even instructions on there how to link it here.
Or go to the IT Short Bus on here for photo hosting info.
gotgasd #749293 05/24/2011 1:30 AM
Thanks for the info. I'll try and see if I can figure it out, if so I'll put some pics of my truck. It ain't beautiful like most of the other ones. I drive it daily and work with it if I need too.
Bullhead
Bullheadjoe #749310 05/24/2011 2:26 AM
Here's a link to an Ebay auction for the same carbiretor:
http://cgi.ebay.com/ebaymotors/HOLLEY-ECONOMASTER-CARBURETOR-CHEVROLET-V-8-2Bbl-NEW-/320563951667
No CFM rating, but it's a Holley replacement for the Rochester small-bore 2-BBL carb that was original equipment on the 283, 307, and 327. It probably isn't as good a carb as the OE Rochester, because it won't be calibrated for a specific engine/trans/gear ratio setup like an OEM carb would be. Typical Holley approach- - - - -make something that bolts on and looks right, and make it work pretty well for a variety of engines. If it works exactly right, it's a fortunate accident.
