1 members (Gdads51),
83
Mod | | | Forums66 Topics128,143 Posts1,056,495 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | I am looking to purchase (black) original style (or as close as possible) shocks for my 57 3100 1/2 ton. Anyone know where to get any that is close to the orginal look? Are they any good? The ones I bought during the restoration were (blue) cheap China made and one has already failed.
Thank you.
Jon
1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Check with your local auto parts store, Napa, orielly, autozone.
I bought front and rears from autozone for my year truck. They had them on the shelf If I remember right they were gabriel. Not to expensive. The rears were black, the fronts were red and I painted them black
"Hecho En Mexico"
They seem to be holding up well, no complaints yet.
One good thing about checking locally is that you dont have to pay shipping, you can look at them before you purchase them, and you can take them back if you have a problem.
Check around for your year truck Good Luck | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | I hear the orginals had a "spiral" design? 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | you might find some NOS original spiral style shocks on e-bay, but I've never heard of a repro or current supplier .... for modern replacements: front shocks - Monroe 3100 [each] or Gabriel 82047 rear shocks - Monroe "Limited Edition" LE10018 [pair] or Gabriel 82060 ['57-'59 3100 uses the same shock as the 3200/3600 on rear] Bill | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Hi Bill, Was waiting for your your thoughts. Do you think if I found NOS they would still be any good after 50+ years? I have a friend that has a 54 Chevy and has the spiril style.
I was looking at the " 1957 Factory Assembly Manual" and the pictures of the shocks do not show any kind of spiril. I will take a look at the ones you talk about above.
Thank you! 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | sheets showing the rear don't show spirals, but Sect 3 sheet 1.00 and sheet 8.00 show the spirals on the front - might even have been that the rears weren't spiral, I can't recall now if that was the case, but I'm sure they more a 'light duty' shock, they were used on most GM cars NOS shocks that've been well stored should be fine, although that doesn't mean they'll last as long as a modern set, there's some rubber in/on them that may have deteriorated ... OTOH there are folks out there who rebuild them, M&S Hydraulics might, and check under Chev parts in Hemmings - here's one in Kansas: [email protected] 913-268-5314 .... of course you'll need to find some originals for rebuilding Bill | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I just bought a 56 & it still has the original spiral shocks. I pulled the rear ones off & they feel real good. I am painting them. & am going to reuse them. I havn't got to the front yet. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Thank you Bill for the links. Forgot to ask what spirals do for a shock?
Wrenchbender, Would you mind posting a photo of those shocks?
Thank you!
1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | YIKES! Those are pricey! Maybe I don't need them that bad....
Thank you "Cletis" 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the spirals don't "do" anything, that's just the way Delco made them for awhile  Bill | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Give the modern Monroe or Gabrieals a try Your pancreas will thank you, and your pocket book JMHO  | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I have a photo of the spiral shock if you still want to see it. I can send it E-mail. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Hi George, [email protected]Thank you! Jon 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Would shocks from a 1960 thru 62 1/2 Chevy fit? There are a pair of rear ones on E-Bay.
Thanks guys!
1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | have to ask the seller, who seems to be a specialist  | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Hi Bill, Contacted the person you found in Hemmings. He wants $800 for all 4 shocks. Bit too much for my pocket book right now.
Thanks!
