| | | Forums66 Topics128,060 Posts1,055,837 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 20 New Guy | | New Guy Joined: May 2011 Posts: 20 | Hi, I'm the new guy and just purchased a 49 Chevy pickup. I need it transported from Montana to Los Angeles. Any suggestions on reputable transport companies would be greatly appreciated. Thank you, Tom
| | | | | Joined: Jul 2006 Posts: 183 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 183 | I was in the same boat a few years back Tommyguns, went to the Stovebolt link and got my '56 picked up in Montana and brought to my door in SoCal. Gas was a lot cheaper then, it will probably run at least $500. Good luck, & post some pictures! Ed | | | | | Joined: May 2011 Posts: 20 New Guy | | New Guy Joined: May 2011 Posts: 20 | Thanks for the info. Ed, I guess i made a new guy error and posted this one on the wrong forum. Tom | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Welcome Tom, That's an OK question for this forum. The Hauling Board is mostly fellow Stovebolters with room for parts. You will find some info on commercial haulers there but it's OK for people to recommend vendors and services they are happy with in this forum. | | | | | Joined: May 2011 Posts: 20 New Guy | | New Guy Joined: May 2011 Posts: 20 | Thank you, old guys appreciate supportive words of advice. I was told by Patrick & Philip in Arizona that this was a class operation. They were correct. Thanks (FNG) Tom
| | | | | Joined: Feb 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 190 | I just had a 47 Stude pk up deliverd from Montana to So Cal 29 palms area. Cost me 700bucks, at todays gas prices I thought it was pretty good. The guy was real quick in my case, if you want his number I will pass it to you. He just had about a 1 and 1/2 ton I think with a trailer, I think that's all he does - I have to find his number or I would post it now - good luck. | | | | | Joined: May 2011 Posts: 20 New Guy | | New Guy Joined: May 2011 Posts: 20 | Thanks, I would appreciate his name & number if you can find it, Tom | | | | | Joined: Feb 2008 Posts: 108 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 108 | Tommyguns - send me the name of who you used off line, I have to get a 3/4 ton 4x4 frame from NC to Ca, soon! | | |
