1 members (WingWright), 103 guests, and 1 robot.
Topics128,049
Posts1,055,680
#747780 05/17/2011 6:26 PM
Did the steering columns have a indicator light on the column for gear selection on auto transmissions?
k10 Offline
Yes. There is a small hole in the auto trans collar for a lightbulb. The bulb lights up the clear shift indicator lens at night. The red pointer is not lit.
k10 #747972 05/18/2011 12:52 PM
Yes the Hydramatic has a small light just behind the indicator.
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
OK. Now I need some direction after not being able to find the answer in the wiring diagram.
RE: 1964 C-10
The gray wire from the gear indicator light socket in the steering column flows thru the dash wiring harness directly to the fuse box, where it is connected into the "GAS GUAGE EXT" along with the tan wire from the fuel sender unit (coming from the gas tank).
The gear indicator light will not illuminate, nor does a test light in the socket illuminate. My fuel guage works.
What's my next step in solving the gear indicator light issue?
IIRC, the gray wire should plug into the harness at the base of the column. You could also hook it to the PANEL fuse.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
gray wires are dash lights, as Brian sez, hook it to the power for them, you don't need it when the suns up wink
k10 Offline
Did you test it with the headlights on?
yes, tested with the headlights on. No results. I know the socket get power and the bulb burns when I disconnect the gray wire for the socket and plug it in directly to the fuse box.
Why not just splice into one of the existing gray wires that powers the gauge cluster lights?
Dash wiring diagram
Hope this helps. I can't see what you're encountering. Good luck.
1963 GMC 1000 Wideside
Ok. Solved. I really did not want to splice into any part of the wiring harness, but was curious as to why the socket wire was wired into the fuse box in conjunction with the gas tank sending unit wire.
Ran the socket bulb for the gear shift indicator to the fuse box and connected it to a separate terminal on the fuse for the dash panel lights. Works only with the lights on and also now has light dimming feature, just like the dash lights.
Thanks for everyone's suggestions!
