1 members (Ponchogl),
108
Mod | | | Forums66 Topics128,281 Posts1,058,466 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 106 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 106 | Were any part of the floorboards made of wood for 1940? The toeboard and floorboard from the firewall to the gas tank box is two pieces of plywood on my 1/2 ton. I'm thinking this was somebody's hack way of accommodating for the steering column swap, but I know they did use some wood here and there in really early cars and trucks.
And if not, is there a source for steel toeboard and floorboards? Thanks!
1940 Chevy 1/2 ton, 12 volt, 350/350th
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Sorry - no wood in floorboards / toeboard. Maybe try Jim Carter Truck parts for some of that stuff. You could also have a sheetmetal shop fabricate it for you. That way it can fit custom stuff like transmission humps and bellhousings. | | | | | Joined: Apr 2011 Posts: 106 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 106 | Sorry - no wood in floorboards / toeboard. Maybe try Jim Carter Truck parts for some of that stuff. You could also have a sheetmetal shop fabricate it for you. That way it can fit custom stuff like transmission humps and bellhousings. That's what I thought. I might just get some sheet metal and make new ones.
| | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | Jim Carter has the floor insert (fiberglass) but not the toe board. Check the for sale section here on the bolt, and place an ad in the wanted section. I've seen used ones on Ebay, too. Good luck!
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | |
