9 members (treegrower, 68ironhead, GRNHydra, Nhluvstruck, 55shaker, MickeyP, elhippie64, David Bush, 1 invisible), 43 guests, and 1 robot.
Topics128,090
Posts1,056,016
Members48,430
#747394 05/16/2011 2:38 AM
I installed a dual brake booster with my disc/drum set up. What I noticed is that my swing pedal doesn't return all the way to the stop/brake switch after the engine has been running and you apply the pedal. It will return after you shut it down and hit the pedal a few times, I guess I'm bleeding out the booster. Does it sound like I need to fine tune my rod adjustment? Thanks G
I assume nothing is binding?
I'm not sure about earlier models but my AD has a return spring that attaches to the brake arm and hooks to the chassis.
Admittedly I had to form a new spring attachment on my chassis,due to the chassis being boxed.
More pix on Flickr.
No nothing binding, I set it up to ensure full stroke of master cylinder and it works fine until you start it and create a vacuum, it's not enough to apply the brakes but enough to keep the pedal to fully return. Now that it is bled out I'll try and fine tune it. Hope to get a road test in this weekend before tearing it back down. Thanks G
Got the same dual or pancake booster on my streetrod. Like jockbolter50 says, hang a spring for a positive and complete pedal reurn. I did to get mine to act correctly. You may not have to tear it down.
Could be a booster issue, or something going on with the check valve on the vacuum line ?. Booster retains some vacuum after you shut off motor - enuf for 1 or 2 pedal pushes. Perhaps it's not fully releasing ?
1940 Chevy KC 1/2-Ton
