1 members (78buckshot), 64 guests, and 3 robots.
Topics128,089
Posts1,056,004
Members48,430
All right guys i'm sure you've heard it a hundred times. Im having trouble finding the correct distributor cap for my 53 gmc 100 with the 228 inline 6. I ordered the "GMC" cap from American Classic Truck parts but it's too shallow the one I have on my truck is MUCH deeper. also i'm having trouble finding the dwell settings for the points for it. I put it roughly .016 gap on the points but i'd like to make it right some one must know. thanks guys
Josh
Josh
3B Offline
Hy Nielsen, welcome, the dwell should be 38 - 45 degrees, set new points to .019", used points .016". The tall distributer cap should be Napa p/n ECH RR162, unfortunately it looks like a 1953 GMC distributor could have a short or tall cap, at least according to my Echlin catalogue, hope that helps.
that helps a lottt thank you
Josh
Hey there Nielsen, heres a link to the distributor cap you probably need:
http://www.classicparts.com/1953-62-Distributor-Cap-6-Cylinder/productinfo/83%2D211/
I had the same problem with mine, except i thought my 51 GMC was a 53
