| | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 15 New Guy | | New Guy Joined: Sep 2010 Posts: 15 | All right guys i'm sure you've heard it a hundred times. Im having trouble finding the correct distributor cap for my 53 gmc 100 with the 228 inline 6. I ordered the "GMC" cap from American Classic Truck parts but it's too shallow the one I have on my truck is MUCH deeper. also i'm having trouble finding the dwell settings for the points for it. I put it roughly .016 gap on the points but i'd like to make it right some one must know. thanks guys Josh
Josh
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Nielsen, welcome, the dwell should be 38 - 45 degrees, set new points to .019", used points .016". The tall distributer cap should be Napa p/n ECH RR162, unfortunately it looks like a 1953 GMC distributor could have a short or tall cap, at least according to my Echlin catalogue, hope that helps. | | | | | Joined: Sep 2010 Posts: 15 New Guy | | New Guy Joined: Sep 2010 Posts: 15 | that helps a lottt thank you
Josh
| | | | | Joined: Apr 2011 Posts: 174 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 174 | Hey there Nielsen, heres a link to the distributor cap you probably need: http://www.classicparts.com/1953-62-Distributor-Cap-6-Cylinder/productinfo/83%2D211/
I had the same problem with mine, except i thought my 51 GMC was a 53 | | |
