| | | Forums66 Topics128,130 Posts1,056,713 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | I removed the rear backrest from my 1946 2 ton truck and this jumped out at me. It says inside an oblong box, Genuine Chevrolet Govenor, The Chevrolet enclosed within the Chevrolet BowTie.Second line in this box says Handi"Vari-Speed" Below this oblong box it says MOD.V5s 141 Manufactured by KING-SEELEY CORP ANN ARBOR MICH.U.S.A. Below this is a list of patent numbers. Another spot shows a VHT 9 46 stamp
Another stamped number shows a 3664924
Do I have something worthwhile here or should I put it in my scrap pile? Thanks for any info. Jerry
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 1951Chevy1Ton, according to my Canadian parts book that governor fits 1946 and 47 1 1/2 ton and 2 ton trucks, if it's still in it's original packaging, it may be worth something to a collector or restorer, hope that helps. | | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | Thank you 3B, I found the description and numbers after I had wire wheel buffed it. I may go to E-Bay with it. Jerry Jerry
| | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | I also found back there a "Emergency Road side flag set" and a wheel wrench and a screw type jack. Any value/ Any Takers? Jerry
