0 members (), 166 guests, and 3 robots.
Topics128,081
Posts1,056,078
Members48,434
#747156 05/14/2011 4:04 AM
The instrument cluster in my '61 C20 is all scratched, broken, and otherwise in need of replacing.
Which years will interchange and fit in my truck?
Husker
'60-'63 Chevy truck clusters will interchange, but the gauge cluster and warning light cluster, require a slightly different underdash wiring harness. 4-5-6 Chevy truck clusters will interchange, but the gauge cluster and warning light cluster, require a slightly different underdash wiring harness. Although similar, the GMC clusters, of the same years, are different, from the Chevy clusters.
The lenses for the Chevy gauge clusters & warning light clusters are available from many of the aftermarket truck parts suppliers, like:
www.lmctruck.com
www.classicparts.com
www.bowtiebits.com
www.truckandcarshop.com
the underdash AND engine wiring harnesses are different between gauge clusters and warning light clusters.
1963 GMC 1000 Wideside
Also, the six cylinder & V8 harness are slightly different.
Thanks, guys! I think I found a '61 cluster. The junk yard is checking to see if it works, and give me some dimensions. And if that doesn't work, I'll go shopping at the above listed stores. I've only been to LMC, so thank you for the other options and info! :-)
