| | | Forums66 Topics128,165 Posts1,056,999 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 24 New Guy | | New Guy Joined: Apr 2011 Posts: 24 | I'm currently installing a 261 out of a late 50s car into my 61 1/2ton 4x4 Carryall.The original engine was a 235.I just realized that the bellhousing is different.Are the timing marks on the two bellhousings the same?Will I create any timing issues if I use my original b.housing on the 261?Are there any other differences I need to consider when doing this swap? | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | You can use your original bellhousing,along with the flywheel,starter and clutch package if you want to. I am using a 235 package on my 261, but with my original 216 bell housing. Carefully check that you are using the right throw out bearing if you purchase new. There are depth differences.
Drew
| | | | | Joined: Apr 2011 Posts: 24 New Guy | | New Guy Joined: Apr 2011 Posts: 24 | Thanks for the info.Are the flywheels different between a 235 and a 261? | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | No, assuming you are using the 235 flywheel from your 61.
Drew
| | | | | Joined: May 2011 Posts: 39 New Guy | | New Guy Joined: May 2011 Posts: 39 | I love this kind of thread. Swapping sixes into anything makes me smile... | | | | | Joined: Apr 2011 Posts: 24 New Guy | | New Guy Joined: Apr 2011 Posts: 24 | Well its done and I'm smiling.The 261 sounds great.I can't wait to put it on the road and try it out.Future plans are to convert it to HEI and to install a one wire alternator. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Well its done and I'm smiling.The 261 sounds great.I can't wait to put it on the road and try it out.Future plans are to convert it to HEI and to install a one wire alternator. Doing the alternator conversion on my 261 this week, although 3 wire and continuing with brake upgrade using dual master cylinder. I haven't run my 261 too much. No mufflers! Elderly neighbors are tolerant, but not all the time. LOL.
Drew
| | | | | Joined: Apr 2011 Posts: 24 New Guy | | New Guy Joined: Apr 2011 Posts: 24 | What is the easiest way to convert from a gen to an alternator?Is there a harness I can buy to plug in?
| | | | | Joined: Apr 2011 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 181 | I put a 261 in my '54 Bel Air years ago and even replaced the torque tube driveline. My end gears are from Goetz (296:1) and it has a T-5 five speed also. Great to drive, smooth runner and good power. The only other changes are a HEI, 12 volt, and a two barrel carburetor. Oh, disc brakes around too. Normbc9 | | |
