0 members (), 51 guests, and 7 robots.
Topics128,021
Posts1,055,355
Members48,420
#746549 05/12/2011 12:36 AM
installing new kings pins in a 51 half ton, the bolt that goes thru the axle to hold king pin in place has a bracket attached to it ( think to stop spindle from turning to much) anyways, does that bracket go on the front or the rear of the axle?? quick stovebolters! whats the answer? im thinking rear. i dont remember
can't remember but you should be able to see what it stops against or see a wear spot where it stops
ron
doesn't that pin go in on a taper
i dont have it, its at a machine shop all blasted and powder coated, its all clean and you cant see that now, im trying to look online but cant find a pic that shows that much detail,
the pin is taperd, as for the hole in the axle i dont think so....
The stop (6.009) looks to be on the tie-rode side of the axle.
http://chevy.oldcarmanualproject.com/1929_54chevyparts/06/379.HTM
thank you
It goes toward the rear of the truck.
