| | | Forums66 Topics128,020 Posts1,055,345 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 114 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 114 | installing new kings pins in a 51 half ton, the bolt that goes thru the axle to hold king pin in place has a bracket attached to it ( think to stop spindle from turning to much) anyways, does that bracket go on the front or the rear of the axle?? quick stovebolters! whats the answer? im thinking rear. i dont remember | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | can't remember but you should be able to see what it stops against or see a wear spot where it stops ron doesn't that pin go in on a taper
| | | | | Joined: Apr 2010 Posts: 114 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 114 | i dont have it, its at a machine shop all blasted and powder coated, its all clean and you cant see that now, im trying to look online but cant find a pic that shows that much detail,
| | | | | Joined: Apr 2010 Posts: 114 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 114 | the pin is taperd, as for the hole in the axle i dont think so.... | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Apr 2010 Posts: 114 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 114 | | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | It goes toward the rear of the truck. | | |
