1 members (LAROKE), 127 guests, and 2 robots.
Topics128,196
Posts1,057,393
Members48,471
#746464 05/11/2011 8:13 PM
LJS
Offline
OK, I just got a flywheel and torus for an early (55-59) Hydramatic. The guy I got it from swears he unbolted it right off the back of a 265 Chevy V8. But it will not bolt up to any Chevy small block crank I have. It has a smaller center hole and the bolt pattern diameter for mounting it is smaller also. It has 6 bolt holes and 3 dowel pin holes. Any one know if there ever was a small block v8 with a different pattern?
Any casting numbers on the flywheel or torus ?
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
3B Offline
Hy LJS, that sounds like a six cylinder flywheel to me.
Nope, gotta call BS on that claim. The small block V-8 crankshaft flange bolt pattern didn't change for 30-something years, until they went to the 1-piece rear main seal. That 6-hole, 3-dowel arrangement is a 6-cylinder bolt pattern.
1955-1959 6 cylinder flywheel and 168 teeth ring gear: 8615574
1955-1959 8 cylinder flywheel and 168 teeth ring gear: 8617327
LJS #746677 05/12/2011 12:55 PM
LJS
Offline
OK, that's what I thought.
I guess I'm still looking for a V8 flywheel.
****WANTED: V8 CHEVY TO EARLY HYDRAMATIC FLYWHEEL******
they are available so keep looking. the flywheel you do have is trading material, I would look for a flywheel from some of the tranny rebuilde supply places like fatsco or northern. they can direct you
