0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | I have been driving the truck a lot and tweaking here and there. It is running better and better. It seems it runs better on long drives rather than short.
I tweaked the timing tonight and took it for a ride and it is better on the hills, very little hesitation and smoother at high rpms.
I will keep driving it and check the compression in a few weeks. I did have a low cylinder (#4 was at 90 all others were at 110)
Could be related to brake in or valve adjustment so I will check a few hundred miles in.
In the meantime I have adjusted my expectations and I am happy with the (about 50%) increase in power and response I am getting. I notice I can maintain 55mph pretty consistently on the highway even on long hills without putting my foot in it.
It has a little better manuverability with the increased torque and response.
Now if that cylinder comes up to pressure I will be a very happy man.
Rich
| | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | Hi Rustbucket53 - Try driving your truck up Converse St. That hill will prove your pulling power/torque. It's the "Pike's Peak" of Wakefield. | | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | wbrowne
I have...it is a block from my house and yes it is really steep.
