2 members (55shaker, 1 invisible),
55
Mod | | | Forums66 Topics128,076 Posts1,055,920 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 15 New Guy | | New Guy Joined: Mar 2011 Posts: 15 | well i finally got my 235 back from the machine shop. after five months of waiting, and locating different parts. so im putting the motor together and sure enough,as precise as i try to be, i cannot find tne bolt that holds on vthe oil pump. i believe it was a specialv bolt with a lock nut on it, and a tapered vend to go into the pump shaft. does anyone knoe where i can get one? any help would be great. thanks
really like the stovebolt site. not the sharpest file in the drawer when it comes to computors. better at rebuilding parts. hope im in thanks guys rodC66
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 216 and 235 use the same bolt.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | You might try and call Jim Carters they have a bunch of "parts" engines in the back of the shop they also have a bunch of old engine parts in the basment.Plus there are alot of parts floating around this site.
Pete | | | | | Joined: Mar 2011 Posts: 15 New Guy | | New Guy Joined: Mar 2011 Posts: 15 | thanks pete52, i called carter and he put me in touch with a used parts man.thev part i need is in the mail. you cant roller skate in a buffalo herd. roger miller 1964
