1 members (texczech), 51 guests, and 2 robots.
Topics128,024
Posts1,055,395
Members48,422
#746208 05/10/2011 8:42 PM
I pulled my fender off this morning.
This mounting point had no bolt in it, and when I pulled the fender off I found a U shaped shim sitting on it. I also found about 4 of the shims lying on the ground. Don't know where they came from.
This mounting point does not look threaded, and I don't see a nut inside.
Comments? Hints? Instructions?
"Happiness equals reality minus expectations" - Tom Magliozzi
the dropped shims came from the same place, body shims are commonly found there - that mount point is always a rot problem, there should be a weld nut inside that lump - the PO prolly found the threads corroded away and shrugged it off, you're faced with taking the piece off and replacing the nut inside or putting it back together the way it was ohwell
squeeze #746242 05/10/2011 10:54 PM
Another idea would be drill out hole and install a wel-nut (the rubber thingy that goes in a blind hole, you thread your bolt in, and it expands and locks in place.) If that's not strong enough or sticks out too far, straighten the prongs on a T-nut, and weld it in the hole. Good luck!
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
