0 members (), 79 guests, and 4 robots.
Topics128,021
Posts1,055,373
Members48,420
Anyone have picture showing the mounting of the strap that goes between the engine and the firewall? This would be for 3100, 55 to 59 1/2 ton, with either engine. Not the battery negative ground
there's a threaded hole on a slight boss on the pass side toeboard, in this pic you can see it's right behind the V8 exhaust manifold - goes from there to a mount bolt on the starter and was originally a braided strap as shown ... sounds like you know the battery ground goes to a similar point behind the battery
Got it thank you, is the nut welded on the inside of the boss square or 5 sided?
no idea, might be round, it's a threaded hole, no access inside
