8 members (HandyAndy, Hotrod Lincoln, baldeagle, Jon G, TexasA&M48Truck, MickeyP, cmayna, 1955 1 Series),
72
7
Mod | | | Forums66 Topics128,022 Posts1,055,352 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 283 Shop Shark | | Shop Shark Joined: Oct 2008 Posts: 283 | Anyone have picture showing the mounting of the strap that goes between the engine and the firewall? This would be for 3100, 55 to 59 1/2 ton, with either engine. Not the battery negative ground
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | there's a threaded hole on a slight boss on the pass side toeboard, in this pic you can see it's right behind the V8 exhaust manifold - goes from there to a mount bolt on the starter and was originally a braided strap as shown ... sounds like you know the battery ground goes to a similar point behind the battery Bill | | | | | Joined: Oct 2008 Posts: 283 Shop Shark | | Shop Shark Joined: Oct 2008 Posts: 283 | there's a threaded hole on a slight boss on the pass side toeboard, in this pic you can see it's right behind the V8 exhaust manifold - goes from there to a mount bolt on the starter and was originally a braided strap as shown ... sounds like you know the battery ground goes to a similar point behind the battery Bill Got it thank you, is the nut welded on the inside of the boss square or 5 sided? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | no idea, might be round, it's a threaded hole, no access inside
Bill | | |
