| | | Forums66 Topics128,005 Posts1,055,253 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | I picked up the ’66 from the paint shop on Saturday and now the brakes are acting up. At the first light the pedal went straight to the floor. I pumped it and after a sharp pull to the left it stopped. The brakes held fine at the light. Next light same thing. If I pump twice they stop fine and hold fine, but not on the first push of the petal. A bad M/C would lose pressure while sitting at the light and I’d start creeping forward – this is not happening.
Long term I’m going to change it over to 4 wheel disc, but if I was hoping to put that off until the ’53 is finished.
Suggestions?
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Feb 2011 Posts: 51 New Guy | | New Guy Joined: Feb 2011 Posts: 51 | I have a 64 GMC, and my brakes work fine after pumping them up too. But at stoplights, they do slowly (sometimes not so slowly) lose pressure.
It's off the painters now, but when I get it back my plan was to bleed the system thinking there was air somewhere. When you say "a bad M/C" what do you mean by bad? There is one place that you have not looked, and it is there - only there - that you shall find the master. | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | Your problem is a bad master cylinder. It needs to be either replaced or rebuilt. The fluid is leaking by seal in the piston. Mine holds pressure it just takes 2 pumps each time.
| | | | | Joined: Apr 2011 Posts: 12 New Guy | | New Guy Joined: Apr 2011 Posts: 12 | It's probably the residual pressure check valve in the master cylinder. Time for a rebuild.
1963 GMC 1000 Wideside
| | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | I would give all 4 corners a visual check & a good cleaning. Check the adjustment, too. Of course, you're looking for leaks, buildup, corrosion, wear, etc. How long before you do your modifications? It might be worth replacing the hoses, wheel cylinders, steel lines, or shoes in the meantime.
cm If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | What the hell is this "takes two pumps" stuff you guys are talking about?! Brakes aren't supposed to "pump up." They're supposed to work when you press the pedal the first time. Rebuild your brake system. The vehicle you slam into might be mine!
-Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | I agree with Brad. You shouldn't have to think about what to do when it's time to stop. You just press on the brakes and it stops. Pull all the wheels and check everything. Rebuild or replace as necessary. Fred
| | | | | Joined: Nov 2008 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 65 | I agree your residual pressure valves aren't working. You can buy separate residual pressure valves on ebay for 10-15 bucks. Pretty easy to install, and might just save someone's life. | | | | | Joined: Feb 2011 Posts: 51 New Guy | | New Guy Joined: Feb 2011 Posts: 51 | Well, my brakes work fine.. but when they start to fade, I just have to pump them. Thanks for the info on the MC, plan is now to rebuild it... just have to wait to get it back from the painter.  There is one place that you have not looked, and it is there - only there - that you shall find the master. | | | | | Joined: Oct 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2008 Posts: 67 | if it takes 2 pumps tha brakes need adjusting, if the pedal fades you either have a leak or the master cyl is junk. | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | I agree that brakes should not need to be pumped to stop, that’s why it went from the shop directly to the house and there it has sat.
We decided to put the conversion ahead of everything else. The problem I ran into with it being a ¾ ton 8 lug floating rear, is no conversion kits to change the rear to disc, unless I wanted to convert to 5 lug. So I rebuilt the existing rear drums (all new parts) and I’m in the process of changing the front to disc. In for a penny in for a pound, everything is getting replaced with new – all 4 tie rod ends, sleeves, upper and lower ball joints, shocks, spindles, rotors, calibers, pads, lines, master cylinder (chrome), power booster (chrome), portioning valve (chrome), and bearings. I think I’m getting close to the $2,000 mark.
I’ll be posting a “free to a good home” for the 8 lug drums, spindles, and hubs if anyone wants them. The drums are in good shape – nice and smooth.
| | | | | Joined: May 2009 Posts: 47 New Guy | | New Guy Joined: May 2009 Posts: 47 | You are sucking in air from someplace that is why you are pumping your brakes! Not SAFE | | |
