2 members (Hotrod Lincoln, Southerntruck), 109 guests, and 3 robots.
Topics128,142
Posts1,056,491
Members48,442
#746037 05/10/2011 2:18 AM
I have a 37 chevy with a 216. Runs great but if it sits a few days the gas drains out of the glass bowl filter attached to the carb. What would cause the suction to happen and how can I stop it.
Steve
1937 Chevy 1/2-Ton Pickup x3
1940 Chevy 1/2-Ton Pickup
1940 Chevy 1 1/2-Ton COE
1941 Chevy 1/2-Ton Pickup
1941 Chevy 1 1/2-Ton COE
1941 Chevy 1/2-Ton Suburban
1946 Chevy 1 1/2-Ton COE
1971 Chevy 1/2-Ton Pickup
StevePala #746081 05/10/2011 3:52 AM
My old fuel line between the tank and pump had a hair line crack in it and was causing the same issue. When i put pressure to it I found the drip. I installed new fuel line.
1959 Chevy Apache 3100/ 283 TBI / 4L60E
My YouTube:
https://www.youtube.com/mikebtte
The fuel pump diaphragm isn't holding the pressure probably due to age or deterioration due to ethanol in today's gas. Hence it's allowing the fuel to drain back. Try rebuilding the fuel pump with ethanol resistant seals etc.
