1 members (Sjm), 149 guests, and 5 robots.
Topics128,266
Posts1,058,385
Members48,485
U
U Offline
Does anyone know where I can get original style spark plug wires for my 1957 Chevy Truck.
Any photos out there showing them??
Thank you!
Jon
1957 Chevy 1/2-Ton Truck
More pix
The coldest winter I ever saw was a summer I spent in San Francisco M. Twain
If at first you don't succeed...skydiving is not for you!
If you don't like my carbon foot print, stick it up your Prius!!
AFAIK the sets sold by most vendors, like so are as close as you'll find, I believe the originals actually had angled ends on #1 and 6, straight on 2-5 ... should be a pic in the shop manual that shows at least some of them .... I got a set from NAPA, the brand had red straight ends at the plug, but they work wink
The 1954 Truck Engineering Features manual shows plug wires just like the ones shown by Bill above (American Classic Parts - no right-angle ends).
However, many of the reproduction parts vendors sell spark plug wires like these - no cover/insulation at the plug end and all with 90 degree plug ends. These were used in earlier years on trucks, through 1953? However, 1953 car engines show the covered ends as used on 1954 trucks.
U
U Offline
OK Thank you!
I see there are some clips missing on my set-up as well.
More pix
I have never seen those original-style plug-wires holders/clips. These O-ring style holders are commonly used.
Or, clips like these?
the American Classic sets include those "O ring" holders, 3 wires bundled in each. I've never used them, the right length wires lay nicely
I think the reason you see the angled end sets for the I-6 is they're what has to be used on the V8 and suppliers are too lazy/cheap to make or stock 2 breeds
First time I've noticed those wire holders Tim. Looks like another one of those little projects that's gonna keep me from working on the trucks.
I've been working most of this year with silicone and casting resins to come up with gaskets for the '54-'55 radios speakers. Also knobs that fit like the original ones, support brackets, driver side pads for converting the passenger radios to truck, the speaker supports, special nuts and spacers, ammeter fuse holders. This week I'm making the molds for the rubber bumpers for the Fresh Air defroster doors and the tool box keyhole plugs under the seat of the '54 and a few other non important little details.
So if I get a chance I just might draw up those two original style plug wire holders and see if it's practicle to cast them in semi-ridged urethane. Looks like the front one is for 2 wires and the rear one holds 3 wires.
DG
Denny G
Sandwich, IL
U
U Offline
I found these at Filling Station...They are Delco:
LINK
More pix
I saw these is classic truck Mag
...link...
Im using some from carquest
...pic... they are gray
U
U Offline
Hi DADS50,
Great link Thank you! I will save this one for when I restore the 65 Convert VW bug
More pix
Originally Posted by UnklRod
Hi DADS50,
thumbs_up
Pertronix sells a black set also
..link...
I ordered that set from pertronix but the lengths were off and some of the wires were to long. I didnt like the boots either.
The best fitting set I found were autolite. Only problem was they are orange. If only I could find that autolite set in black.
...auto lite wires...
I also tried the shiny black ones the vendors sell.
They look more original but it was a shocking experience.
Only used them for a day
...pic...
Good Luck
