Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Hanks custodian, rfs56trk, LAROKE), 146 guests, and 4 robots.
Topics128,290
Posts1,058,584
Members48,492
Where can I get some chrome valve cover, oil pan, timing gear cover etc....
Might be helpfull to know for what?
There are plenty of them on Ebay- - - -but be sure and buy a couple of cases of oil when you get them. They leak!
Chevy 261 CID inline six, casting numbers indicate the block made in 1954.
I would have to say a good heavy cast valve cover would be the way to go. But all the cast have center bolts like the 216. They are also pricy. Classicparts.com or www.stoveboltengineco.com
1959 Chevy Apache 3100/ 283 TBI / 4L60E
My YouTube:
https://www.youtube.com/mikebtte
Thanks to all for the info, I guess I'll have a look. Also the advice about the cast vs stamped thanks!
Here are some machined, aluminum billet timing gear covers from Seven Gems for Chevy and GMC sixes.
Doug Lee might make a custom oil pan for a 235 or 261. He did for my 1954 261-powerd street rod to clear a GMC oil pump
Hoyt
