1 members (Eileen),
271
Mod | | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 152 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 152 | My 1959 38 flatbed needs 2 tires and I have found an individual with 8 never mounted 7.00-18 bias ply tires at a very good price. Should I be concerned about the tires having the correct tire-to-rim lip to fit my original split ring wheels? I understand tires may have either a 5 or 15 degree mountng lip. It is important to gather as much information as possible in advance since I will be driving almost 200 miles round trip to get the tires and I sure don't want to buy tires I can't use.
Thanks, Steve
Oldbolter 1959 Apache 3800 dually flat bed/dump with 261 1956 3800 dually flat bed/dump with 235 1957 3600 flat bed, 350 engine, 700R4, PS, disc brakes, 14 bolt rear with 4.11 gears
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Assuming you have 18" rims already? Sounds like the tires you need then.
Old "new" tires even cheap won't always be a good deal. I ran some new never used but 20+ year old (even stored inside) goodyear 8-19.5 tires on my truck and they did fine for about 10,000 miles but then both rears started to loose sections of tread. The tires were free and served me well, but had I paid anything for them I would have been a little disappointed.
Grigg | | | | | Joined: May 2010 Posts: 42 New Guy | | New Guy Joined: May 2010 Posts: 42 | I recently purchased 6 7.00-18 for my 1946 3800 dually. It was expensive at about $1300 for tires, freight and installation, but worth it to me. There are not many options these days for that size tire (I bought the Super Transports) and I don't know about the 5 or 15 degree lip, but so far so good for me. | | | | | Joined: Aug 2009 Posts: 152 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 152 | Grigg and Overgripped,
Thanks for your responses. After very careful inspection and checking the manufacture date, I purchased four new/old (several years old, but never mounted) tires today. I plan to mount 2 of them and keep the others for spares.
| | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | I stopped in the tire store today, an old full service tire shop in a farming community, which handles everything from wheelbarrows to lawnmowers, cars, truck, tractors, and semis. He had no qualms about dismounting/mounting, but told me that the dismount, tire, tube, flap, and remount, would be $250/tire. Ouch. But, ya gotta have them!
I'll do lots of things, but I don't do tires!
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | ...He had no qualms about dismounting/mounting, but told me that the dismount, tire, tube, flap, and remount, would be $250/tire. Ouch. Ouch! is right. Wow, you better get a few more prices on that job. For that kind of money you can buy a new 8 lug 19.5" tubeless wheel, and have a tire mounted and balanced. Grigg | | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | Grigg, I'd love to see some pictures on a one ton of the 19.5 wheel. I've had it in the back of my mind, but I just can't visualize it, and am not sure that I want to do something that will drastically change the appearance of the truck. If you have some pics, please point me to them or email me at [email protected] | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I don't have the exact picture you're looking for. Here's what I do have http://rides.webshots.com/photo/1484222726080251109dhsKhxThat's 8-19.5 tires and the front wheel is similar but not 8 lug. The 8 lug wheel you'd be looking at is an Accuride part number 29015 found on page 28 http://www.accuridewheels.com/completeversion.pdfOr to keep the original look with all those hand holes in your wheels I'd contact http://www.ricksontruckwheels.com/ and see if they can reuse your centers in new 19.5" rims. I'm not sure if the measurements work out and how likely that is, but worth investigating, in fact if you measure the Id of your wheel, which is the OD of the center I'll compare that to a 19.5" rim. Also give me the mounting surface to center of rivet holes on the center. If that works I suspect it'll still be more economical than $250 for tube, flap, and mounting. Grigg
| | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | ID of the wheel - 18" Center of hub to rivets - 8-3/4"
The rear is DRW with a stakebed, so clearance isn't an issue. Just curious how those 19.5 wheels/tires will clear/not rub.
jg | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | You sure the diameter of the wheel center is 18" and not something like 17.5"? I guess I'm asking if you were to put that center in a new rim what would size will it fit in without any machine work? Also to double check, the wheel center it's self has 8.75" dish in it from flange to rivet holes where it attaches to the rim?
8R19.5 tires sholdn't have any problems with rubbing or clerance, I didn't have any although my truck was not quite stock.
Grigg | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | 8 3/4" centre of hub to rivets =17 1/2" dia + the thickness of the centre on both sides should equal 18" ron
| | | | | Joined: Mar 2005 Posts: 171 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 171 | these are 19.5 wheels from a P30 stepvan with 8R19.5 tires http://rides.webshots.com/photo/2620734620106850169lkHiphstock 3800 suspension no clearance issues. 7.50-17, 7.00-18 & 8R19.5 tires are all very close to the same height. I've got some of the old 18" multi-piece wheels. I took the center out of one to see if it would go in one of my 19.5 rims. sadly it was about 3/16-1/4" too big. I'm going to put some mold release wax on a rim & lay some fiberglass on it to make a pattern where I can make 4 more holes in the wheel center using hole saws. An 1 & 1/4" for the ends & About a 3" for the middle will reproduce the oval hole in my rims with 4 little ears left to clean up with a die grinder. I'll document with pics when I do it & I'm sure I can get them close enough the wheel will balance fine. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | ... I've got some of the old 18" multi-piece wheels. I took the center out of one to see if it would go in one of my 19.5 rims. sadly it was about 3/16-1/4" too big... That's the info I was trying to measure and figure out, I just don't have an 18" wheel to work with. The other measurements in the previous post are confusing and not so much help I don't think. So, with that info sounds like an original center can be turned down, possibly loosing the lip with the rivet holes, and then welded into a 19.5" wheel (how modern ones are made) Only question left is does the dish of the wheel work out with the drop center on the 19.5" wheel and can you actually build a wheel that gives you the correct offset /dual spacing? Grigg | | | | | Joined: Mar 2005 Posts: 171 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 171 | I also looked at turning the lip off but what you'd have left would be too shallow to give enough offset. | | |
