7 members (Gdads51, Phak1, Joe H, Youngin' Tut 59, Greg_H, carbking, Wayne67vert),
99
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,137 Posts1,056,430 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 219 'Bolter | | 'Bolter Joined: Jan 2007 Posts: 219 | I am considering gluing on the running board seal that runs between the body and the running board.I would be gluing it directly to the painted surface What should i use for glue? I was thinking PL Premium
layback
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Many glues and paint don't live well together. You might get by using weatherstrip adhesive.
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I used 3M Weatherstrip Adhesive with good results for installing fender welting and rubber seals on painted surfaces | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Is this for a AD?
Under the rocker panel | | | | | Joined: Jan 2007 Posts: 219 'Bolter | | 'Bolter Joined: Jan 2007 Posts: 219 | Yes 1954, sorry about that.
layback
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | American Classic Truck Parts Offers the retainers for that seal for $8.50 each Screw set is $2.00 Part # CB136 Dont know if the part is the same for your panel but may be worth looking into. Maybe you can modify the pick up retainer to fit your application Good Luck | | |
