| | | Forums66 Topics128,190 Posts1,057,342 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 58 New Guy | | New Guy Joined: Mar 2011 Posts: 58 | Rummaging through container #6 I found what was identified by HAMB'ers as a "Nash" style distributor. It has 2 coils and 12 plugs but appears to be modified by "Fisher ignition". I would like to put this cool doodad on the 302 I am building. The rotor is offset with two contacts and the cap is plugged off for six wires. What would I have to do to make this work? It looks like it bolts on to stock GM housings. I'll post pic's later today. I have spare caps and rotors as well. Would I be able to convert this to a pertronix HEI as well? This Dizzy is too cool for school... what a conversation piece it would be!!!! | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | That dizzy is for the Fisher crossflow head for the Chevrolet engine, I beleive. IIRC, that head used dual plugs.
Bill Burmeister | | | | | Joined: Mar 2011 Posts: 58 New Guy | | New Guy Joined: Mar 2011 Posts: 58 | Thanks Longbox.... got to talk to pops later today, he was having a pretty okay day. He remembered that the Dizzy was set aside for his Wayne Head. Dang!! Oh well, I'll get to use it soon enough, just not for this project. Can I get an HEI kit for the stock Dizzy???? | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Pertronics makes an electronic conversion for the stock distributor to replace the points. HEI distributors from the 250 and 292 can be made to work with a little machining. Tom Langdon and others sell an HEI distributor that has already been machined to fit the stovebolt and gmc engines. The wires used are from a 300 f*rd inline.
| | | | | Joined: Feb 2004 Posts: 29,881 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,881 | I've seen a tech tip somewhere that involves fitting a Mopar 6-cylinder electronic ignition trigger to a stovebolt distributor to replace the points and condenser and retain the stock-appearing small distributor. Its advantage is that it uses all off-the-shelf parts from the FLAPS rather than the proprietary Pertronix stuff. The output developed by the Mopar signal generator is used to trigger a standard GM HEI module and electronic ignition remote coil. Jerry
| | | | | Joined: Mar 2011 Posts: 58 New Guy | | New Guy Joined: Mar 2011 Posts: 58 | | | |
