9 members (wilbur53, KEVINSKI, Wayne67vert, Lostbuthaulinass, Otto Skorzeny, 1955 1 Series, Peggy M, tclederman, 1 invisible), 104 guests, and 3 robots.
Topics128,142
Posts1,056,478
Members48,441
I am considering gluing on the running board seal that runs between the body and the running board.I would be gluing it directly to the painted surface What should i use for glue? I was thinking PL Premium
layback
Ex Hall Monitor
Ex Hall Monitor
Many glues and paint don't live well together. You might get by using weatherstrip adhesive.
I used 3M Weatherstrip Adhesive with good results for installing fender welting and rubber seals on painted surfaces
1940 Chevy KC 1/2-Ton
Is this for a AD?
Under the rocker panel
Yes 1954, sorry about that.
layback
American Classic Truck Parts Offers the retainers for that seal for $8.50 each
Screw set is $2.00
Part # CB136
Dont know if the part is the same for your panel but may be worth looking into. Maybe you can modify the pick up retainer to fit your application
Good Luck
