| | | Forums66 Topics128,107 Posts1,056,225 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#74562 03/10/2007 4:43 PM | Joined: Jan 2007 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 136 | I am trying to plan ahead on my 55 second series. I have doing a lot of thinking and I want to add an IFS. I like the idea of a bolt on kits, but am not excited about the cost. So I have been reading a lot about adding a front clip from a donor car.
When someone says that they went to a salvage yard and picked up a front clip, does mean they actually cut the front of the frame off of the donor frame right there in the salvage yard?
I realize this is a VERY basic question, but I am definitely a beginner with time, interest, who is struggling on some of the mechanical issues of this project.
Thanks for any advice.
Ross | | |
#74563 03/10/2007 5:06 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Ross - any "clip" you might want to use will be a pretty straight forward frame subassembly that most wreckers would remove for you ..... might even have already on the shelf
but that won't be a bolt on item, nor necessarily cheaper, and if you don't have a pretty good understanding of designing a front end for your truck, including how to remount the rad, which locates and mounts the front sheet metal, you might save yer pennies for the bolt on unit, which doesn't require cutting the entire front off the original frame and welding a new one on
you may be better to get the truck into useable stock condition, we can help with the mechanics ....
Bill | | |
#74564 03/10/2007 5:56 PM | Joined: Jan 2007 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 136 | Thanks for the advice Bill.
I like the sounds of that better. I was really nervous about screwing something up.
Do you know if the bolt on kits pretty straight forward?
Thanks again!
Ross | | |
#74565 03/10/2007 6:17 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | well, they're fairly straight forward in terms of everything being the right shape, width, etc if it's a kit designed for the year, but depends on you if that = easy .... you're looking at changing brake setups and 6 lug to 5 lug, so there are still considerations that affect the entire build up the best plan is to figure out what you really want in a finished truck and plan it as a package - if you just want an ocassional driver that's out of the ordinary, stock does the trick, if you want something that rides like a car, the modifications can be mild or extreme ... I just like a dependable, easy, workin mans truck Bill | | |
#74566 03/13/2007 1:21 AM | Joined: Feb 2007 Posts: 8 Junior Member | | Junior Member Joined: Feb 2007 Posts: 8 | My wife, YES WIFE, with no mechanical experience but a good mentor (not me) put a bolt on mustang type II front end on a '36 dodge pu. She stripped the frame and boxed it herself. Once mounted, you can get a wheel shop to set all the adjustable stuff.
Me on the other hand, am doing what you were talking about. I am choping the whold front end off a '78 burb and puting it in a '65 C20 with engine, trans and everything.
Hers is finished. I am just starting. Who know if I will ever finish. | | |
#74567 03/13/2007 1:32 AM | Joined: Oct 2006 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 37 | the first question is a good one , what you need to do that is going to be very much less costly than any kit you buy , you need a 1970 thru 1981 GM front subframe from one of three car's #1 nova #2 camaro #3 firebird these front subframe's unbolt from the car but will be welded back into your truck this is a very popular thing to do , the truck will drive and handle great !! I would look for a junk nova in a four door subframe is the same but the car and part's on it will be cheaper because of it being a four door , heck a friend of mine bought a 77 four door nova for $300 buck's and drove it home ,,,
1967 C10 shortbed fleetside 1/2 ton painted bumper's & hubcap's no option's driven year round but truck won't start when it's raining or snowing ? 1967 camaro RS 327 all stock DON'T WORRY FOLK'S THIS BIG WHEEL THING IS LIKE A KIDNEY STONE IT WILL PASS ! O-RING'S WERE NEVER MENT TO BE USED AS TIRE'S ! 1967 c10 2wd swb 250 3spd | | |
#74568 03/13/2007 6:24 PM | Joined: Oct 2004 Posts: 128 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 128 | Take a look under tech tips on this site. There is a very good article on installing a front clip. When done this way it opens you up to almost any GM front clip. You will also realize it is a lot of work, and requires some fairly good fabrication skills, a welder, and plenty of room. In your case it sounds like bolt on might be the way to go.
John | | |
#74569 03/14/2007 1:20 PM | Joined: Jan 2007 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 136 | Thanks to all of you!
All of your advice is very helpful.
My son and I are having a ball working on this truck and all of your advice is taken to heart.
As of right now, I am leaning towards the bolt on kit (the realistic side of me). However, I am still going to read up on using an older gm clip as described by 19673ontree. The other side of me still wants to go for it and have to do some creative work.
Time (and money) will tell.
Thanks again!
Ross | | |
#74570 03/14/2007 1:57 PM | Joined: Nov 2006 Posts: 180 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 180 | welcome to the site. I am in the process of getting ready to weld in a Camaro subframe on a 1950. If that is the route that you decide to go, I know that I am not the first one to do so, and there are probably a few of us that can help you struggle through it! haha. Take care and enjoy the site.
1950 Chevy 3100 5 window "in progress" 1967 Chevelle 300
#74571 03/14/2007 3:30 PM | Joined: Dec 2002 Posts: 3,441 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,441 | welcome to the 'bolt... I would hesitate at tackling a clip job without someone who knows what is going on... the IFS kit, however is pretty easy to install... just measure everything about 100 times and ensure that you MARK the centerline of your wheels before you tear it apart.
#74572 03/16/2007 2:48 AM | Joined: Feb 2007 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 52 | 1st Project. There is no better way than learning and doing it your self. Before you go the "sucker" way, and I meen that with all loving care and kindness. Get your self some books/videos and look on the internet. You will be suprised what you see and can learn. Heck watch a couple Saturdays of Horsepower, 4x4, and Trucks TV shows. Than you will have a better understanding of what is going on. Make your decision from that point. Kenny B. | | |
