8 members (lumbersawyer, JW51, 3B, cshades, cmayna, Gdads51, moparguy, 1 invisible),
102
Mod | | | Forums66 Topics128,064 Posts1,055,860 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2002 Posts: 3,440 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,440 | I installed a NEW ground cable on my truck some time ago. Shortly afterwards, I started having starting problems.. indicating a dead battery. Since the battery was 7 years old, I put in a new one.. problem solved, for about 2 weeks, then back to the same problem.
The Solenoid would click and the entire electrical system would die. No volts except at the battery. 5 minutes later, the power would magically come back on!! WTH? The new Battery would often read 10 volts or less after a starting attempt. I pulled the battery and put a long slow charge on it and had the FLAPS put a load test on it... good battery.
I pulled the starter and found a cracked solenoid cap... new starter.. same problem.. WTH?
I put on an extra ground cable from the engine block to the frame to the back of the external (drof type) solenoid... same problem...
I pulled out the battery again, to install a known good battery... same problem. WTH?
While I'm messing with the batteries, I noticed that the battery ground cable was a bit loose in the socket... continuity is good from the (neg) battery post to ground... same problem...
I got the wild idea to put a jumper cable on the negative post to the frame ground...
Truck started right up...
| | | | | Joined: Aug 2010 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 46 | problem solved........way to go!
1951 GMC 3 window 100 1951 GMC 5 window 100
