2 members (Shaffer's1950, 1 invisible), 84 guests, and 2 robots.
Topics128,196
Posts1,057,391
Members48,469
I've found that the torsion bars for Chevy trucks carry a different part number for right and left, but they're the same bars for 1/2- or 3/4-ton trucks.
I want to find out if GMCs had the same torsion bars, or if they were beefier.
Anybody have the part numbers for GMC t-bars?
-Brad
SOUTHERN FALL GABfest
October 6 ~ Commerce, Georgia
Details here!
Never Pee on an Electric Fence.
k10 Offline
Here ya go.
3766852 IFS-025......RH*45 3/4 IN - 1 red band
.......51 ......LH - 2 red bands
3753878 IFS-030......RH*45 3/4 IN - 1 Green Band 1500
.......77 ......LH - 2 Green Bands 1500
3766854 IFS-030......RH*45 3/4 IN - 1 Yellow band 2500
.......53 ......LH - 2 Yellow Bands 2500
3766856 IFS-040......RH*45 3/4 IN - 1 Orange band
.......57 ......LH - 2 Orange bands
There are also the 58 and 70 inch bars which I did not include here.
Originally Posted by k10
Here ya go.
What are the 1500 and 2500 numbers?
Is there a notation as to which part number goes with which application?
-Brad
Details here!
k10 Offline
They are listed in order of size of vehicle. The above is transcribed directly from the parts manual, so anything else is conjecture. But here goes. The top pair of lines should probably have 1000 after each of them to annotate a 1/2 ton truck. The next 2 pairs show 1500 and 2500 to denote 3/4T and 1 ton respectively. That would be the GMC nomenclature starting in 1960 for the weight ratings.
So the short answer to your question would be that the GMC 3/4 ton bars are not the same as the GMC 1/2 ton bars.
I take it that the Chevy and GMC p/n's are not the same? They rarely are.
I know a guy that's been able to track down just about any chevy part number you'd ever want. He sent me Chevy numbers for the torsion bars:
The 1/2-ton and 3/4-ton Chevy list the same part number, which surprised me.
It's the same number as the GMC 1/2-ton.
Once I compared the Chevy and GMC 1/2-ton numbers, I also figured the next two were 3/4-ton and 1-ton.
I wonder what the forth set is?
Did GMC ever have an inline 6 in '60-'62
-Brad
Details here!
k10 Offline
Yes, but not in the pickups. It was in the Dubl Duti forward control trucks.
Fourth set is probably for the series 40 (Chevy, 4000 for GMC)trucks. There are a bunch more part numbers for the bigger trucks. 58 and 70 inch as well as some more heavy duty 45 inch rods for the COE trucks.
Huge help! Thanks!!!
-Brad
Details here!
k10 Offline
Glad I could help.
i have a set brad
I'm actually investigating everything I can find about them to start having them made, because replacements aren't available (that I've found).
-Brad
Details here!
