| | | Forums66 Topics128,088 Posts1,056,122 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2002 Posts: 126 | I am putting the head back on the 216 soon and have just a couple simple questions. First, I did not keep the push rods in order when I took them out...I may have read it is important to keep them in order. Is this true and if so what now?
Second, the head gasket I bought yesterday is a Fel-Pro 7276 B. It says use no sealant...should I trust this?
Chris Simmonds 1942 Chevy 3/4 ton | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Push rods wear in, mainly at the top, to the adjuster ball. If they are mismatched they may go out of adjustment fast until they wear back in to their new spot. This is no problem, just means you may need frequent adjustment at first.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Mar 2002 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2002 Posts: 126 | Push rods wear in, mainly at the top, to the adjuster ball. If they are mismatched they may go out of adjustment fast until they wear back in to their new spot. This is no problem, just means you may need frequent adjustment at first. Thanks! I'll go tackle that head then. Chris.
