7 members (Gdads51, Otto Skorzeny, Wally / Montana, LuckyLee, MickeyP, TUTS 59, kades51),
72
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,051 Posts1,055,705 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 97 | I have replaced the sending unit, wiring and fuel gauge in my 1953 3100. The gauge does not work. I have 12 volts coming from the gauge to the sender wire with it disconnected from the sender. When I connect the sender wire to the sender, the voltage drops to .32. The voltage is present with the key on or off. How do you "properly ground" the gauge? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | What kind of gauge is it? I had a similar problem With a replacement gauge and had to clean the paint off the inside of the cluster for a good ground. Pic | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the sender IS the ground, the gauge gets + only .... if you have 12V showing at the [disconnected] sender wire to ground with the key off, you've wired something wrong - gauge power comes from the ignition switch so there should be no power there until you turn the key on
the way it works is the gauge gets a variable resistance to ground as the float moves, changing the current thru the gauge to move the needle .... look at your wiring diagram and recheck your wiring job .... also check the sender itself with your ohmmeter to see if the resistance varies from about 0-30 ohms as you move the float arm and make sure the tank is grounded so the sender is getting a good ground
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | I think you're saying you have 12 volts at the sender terminal of the guage with the sender wire disconnected? If so, that's probably a good reading but doesn't really prove where the trouble is. With the sender wire disconnected from the guage and the key on - what does the guage read? It should swing over to the Full mark. If it doesn't, check your ground at the guage cluster as DADS50 suggests, if that doesn't cause the guage to swing to Full with the sender wire disconnected, you've got a bad guage. | | | | | Joined: Jan 2005 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 97 | Ok..here is what I have. With my wiring issue corrected, I have 12 volts to sender on tank with key on and 0 volts with key off. The tank is full, but the new gauge reads empty. With the sender wire disconnected, the new gauge still reads empty. I get 0 to 32 ohms on the sender from E to F. I will check the ground at the gauge tomorrow. If that is good, then I guess I got a bad gauge...is that correct? | | | | | Joined: Jan 2011 Posts: 138 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 138 | Power goes from the fuse board (or whatever you have) to the gauge. Then that power goes through the sending unit, to the ground.
So the order goes-
12v power --> gauge --> sending unit --> ground
Alex 57' 3100 (The Bondo Bandit) Bad rust and worse wiring, but so much fun.
| | | | | Joined: Jan 2005 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 97 | I've got a new gauge in and during installation of the gauge I noticed a small piece of cardboard like matierial between the back of the gauge and the screws holding the gauge on the cluster. The material was brittle and broke to pieces as I removed it. The same piece of material is on the back of the Ammeter. Does this material serve a purpose and/or should I replace it with something?
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | yes, it serves a purpose - to prevent the terminals from shorting to the case, you should definitely replace it
Bill | | | | | Joined: Jan 2005 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 97 | What could I use? Would a piece of rubber work? Cardboard? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | rubber might work if you got a piece of very thin neoprene .... or cereal box cardboard .... or the thin plastic like used in notebooks or photo albums
Bill | | | | | Joined: Aug 2009 Posts: 295 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 295 | I would use nylon washers. Good strength and insulation
Dan Bentler | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | I would use nylon washers. Good strength and insulation
Dan Bentler the original insulators, at least on the 55-59 trucks, were designed to also prevent shorting the wire connectors to the case or each other, it covers a large part of the gauge back and has a 'wrinkle' that stands between the terminals Bill | | | | | Joined: Jan 2005 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 97 | I'll give the nylon washers a try. I have a new gauge...should there be continuity between the terminals? I have no continuity. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | AD should be the same. With a little red tag on one terminal ...pic... ...pic... LMC and others sell a insulator kit with that tag Or just make your own as suggested above Captain Crunch would work well | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | .... Captain Crunch would work well well 'father knows best'  note the red tag warns 'if hot wire touches, sender will be damaged' Bill | | | | | Joined: Jan 2005 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 97 | What about continuity between the terminals. Should there be continuity? Without continuity between terminals, how would power get from ignition through gauge to sender? | | | | | Joined: Jan 2011 Posts: 138 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 138 | Yes there should be continuity, or as you stated the sending unit would not get power, and the gauge wouldn't do anything
| | | | | Joined: Jan 2005 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 97 | The gauge doesn't work installed in the cluster...with my multimeter on the audible setting I get no sound across the terminals. With the meter on the ohms setting, I get 196 across the terminals. I have twelve volts going in the gauge. With the sender wire disconnected, I get nothing on the gauge. Does this mean I have a bad gauge? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | There are two coils in the gauge. Nne coil is powered by the supply and is grounded through the instrument frame. The other coil is connected to the sender. With the gauge out of the dash, you should be able to apply input power and ground the frame and the gauge shoudl read full. | | | | | Joined: Jan 2005 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 97 | Ok...I suppplied power to one terminal and grounded the frame of the gauge....still empty. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | and grounded the frame of the gauge....still empty. the gauge grounds in the back, not the frame of the gauge ...pic... in that pic you see a matal plate with a gob of solder. That plate need to be grounded for the gauge to work. when installed, it grounds to the gauge cluster. Is that the style gauge you have? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Since this happened with two gauges, why not try this on the old gauge while it is out of the dash. With nothing attached to the sender post and power and frame ground applied, it should read full. Grounding the sender post should create a reading of empty. | | | | | Joined: Jan 2005 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 97 | yes...I have this still gauge. I have applied 12 volts to power terminal and grounded small area with solder...still reads E. | | | | | Joined: Jan 2005 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 97 | I performed all of the testing suggested and never get anything but E. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If you look at the picture supplied by Dads50, you can take an ohm meter and measure between the supply post and the ground plate. You should get a reading, probably around 30 ohms. If that is the case then applying power across there thsould cause the meter to move. | | | | | Joined: Jan 2005 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 97 | Between power terminal and ground plate...on the first "new" gauge I get a reading of 296 ohms and on the second "new" gauge I get a reading of 0 ohms.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I would think that there is something wrong in both cases. The second case sounds like it is shorted. | | | | | Joined: Jan 2005 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 97 | I sent both gauges back today...I guess I'll try another supplier. | | |
