| | | Forums66 Topics128,022 Posts1,055,386 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 4 New Guy | | New Guy Joined: May 2011 Posts: 4 | First of all, happy to find this forum...already learned a lot, great forum!! So I just purchased a 59 chevy apache which is pretty much stock 235 six but thinking seriously about swapping in a 283 and going auto on the floor. My buddy has a 70 chev p/u with a rebuilt 283/ and turbo 350 tranny...use the power steering etc. This a good candidate? I thought about keeping the six but it making a hollow knocking and they want $1400 for rebuild, I can grab 70 truck for $1000. Any thoughts/suggestions? I think i saw a motor mount kit that goes in the 59 Thanks! | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Ediddy, welcome, a 283 would be a fairly easy swap, but with an automatic I would recommend using a tubular crossmember to mount the engine using it's side mounts rather than the original front engine mounts. Also you'll need to to install a crossmember to support the rear of the transmission as well. You'll be able to use the power steering pump, but you'll probably have to buy a kit to change the truck over to power steering, as the steering system is totally different, hope that helps. | | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | I bet you'll come across $400 worth of tweaks and mods you'll have to address when putting in the 283 and auto trans. For me, I'd prefer to spend the $400 on a new engine, keeping it original.
To each his/her own.
Welcome to the 'Bolt!
Bill | | | | | Joined: Oct 2006 Posts: 76 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 76 | Why not use the front mounts with an auto trans? Just curious. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Why not use the front mounts with an auto trans? Just curious. It leaves too much distance between the front mounts & the mount on the rear of the trans. It will break the trans. case. If you use an automatic you will have to remove the crossmember under the bell houseing. I leave the manual trans in mine. The v-8 engine is a simple swap. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2009 Posts: 220 Shop Shark | | Shop Shark Joined: Nov 2009 Posts: 220 | Diddy -
I have the very same truck, 'cept mine is an original V8 truck. One thing you may want to strongly consider before you swap the engine or tranny is swapping the rear end. Keep in mind that your truck has 4:56 gears in the rear, so, regardless of your engine choice, your top end will be 50 - 55mph MAX, and the engine will be screaming. Performance may be a little different depending on the type of auto you swap in, but the gears are low no matter how you cut it.
Why not leave it a stick? Shifting gears is fun, and gives you a whole lot more control.
I'm in the process of swapping in a Dana 60 rear end from an 88 Dodge pickup, and it's really not that much of an ordeal. You'll have to swap the yoke, modify the spring perches, and get an adapter for the brake lines, but none of it is rocket science.
Something to think about...
Chris | | | | | Joined: Dec 2009 Posts: 194 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 194 | I did the swap on a 58. Crate 350 with a th350,power steering and tilt steering wheel. Just finished install of a blazer rear end with 3.08 gears instead of 3.9 this makes a good street driver.All pretty much straight forward. New motor mounts front and rear,reworked the drive shaft for correct length. Changed the spring mounts on the rear end,used the original e brake cables. Kept the 6 bolt hubs. Tachs at 2500 at 65mph. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | Chris - the 4.57 gears are in 3/4T, the 1/2T's have 3.90's standard
Bill | | | | | Joined: Nov 2009 Posts: 220 Shop Shark | | Shop Shark Joined: Nov 2009 Posts: 220 | Squeeze -
Thanks for the correction...I'm still learning as I go...
Chris | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | You should take another look at the 70 truck with a 283 in it. It could be a 307 or possibly a 350. Not that there is anything wrong with any of these engines but it's not likely that a 70 has a 283. There were a number of changes such as the mount holes in the heads which attach alternator brackets, PS pump, etc., which the 283 did not have. If you stay with the standard trans you will need a V-8 bellhousing and flywheel. As 3B states you will need the side mount and rear mount crossmembers if you use the auto trans. Also a cooler or a new radiator set up for an auto trans. Factor in other items such as exhaust, trans shifter, and possibly a drive shaft. Fred
| | | | | Joined: May 2011 Posts: 4 New Guy | | New Guy Joined: May 2011 Posts: 4 | Ya, the 283 is not original to the truck from what I understand...I would prefer a 4 or 5 speed tranny but the 70 I got has the turbo 350 in it so was entertaining that idea. Figure I'd need to switch out the stock tranny? What about using the rear end out of the 70? Or is that not a good match? I appreciate all the feed back! This is my first non air-cooled project! I've always wanted an apache since I was a little guy, really looking forward to digging in! | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | The 70 rear end could work. It will probably require some cutting & welding on the spring pads. Also be aware that the wheel bolt pattern will be different. 6 lug vs 5 lug. The small block with 350 auto combo is a very common switch for these trucks. You should be able to find lots of info on the conversion.
Fred
| | | | | Joined: May 2011 Posts: 4 New Guy | | New Guy Joined: May 2011 Posts: 4 | Thanks! Both trucks have the same 6 bolt pattern, what's your recommendation on a good site for picking up mounts etc? | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | I get most of my stuff from the Truck Shop only because they are close by, I don't have to pay shipping, and can take things back when they mess up. Brothers is good as are most suppliers listed on this site. Fred
| | | | | Joined: May 2011 Posts: 4 New Guy | | New Guy Joined: May 2011 Posts: 4 | I think I've decided to go w/ new 4 speed (old won't bolt up), hydralic? if I head to a salvage yard, what would be a good donor vehicle to look for? Also....what would be the best solution for power steering...full column out of a van? | | |
