7 members (Southerntruck, jaycoop, Joe H, WICruiser, 2-Ton, 42465967, Shade Baby),
114
Mod | | | Forums66 Topics128,129 Posts1,056,362 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 29 New Guy | | New Guy Joined: Mar 2010 Posts: 29 | Hello all, swapped my rad for a 4 core aluminum rad. Still running original 216 with a 180 thermostat. Mechanical temp gauge wont come up over 160. Motor has a slight hesitation under quick acceleration that I cant get rid of. Would this low temp have anything to do with that?
Thanks! | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | a good 180 thermostat will not open until the water in the engine is 180, or slightly over, either you have a bad stat or your gauge is wrong, better do some more specific checks, like different points of the system with a laser digital thermometer and the stat in a pan of water on the stove to see what temp it opens at .... for the hesitation, that'll most likely be in the carb
Bill | | | | | Joined: Mar 2010 Posts: 29 New Guy | | New Guy Joined: Mar 2010 Posts: 29 | Carb is brand new, just bolted it on. Could need the air screw adjusted. Does the carb have any other adjustments? | | |
