0 members (), 108 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
Greetings Stovebolters
Does anyone know where I can find new "side gears" and differential gears for a 53 3100 rear end?
Thanks in advance
Walt Williams
La Verkin, UT
Might check with Patricks, he sells lots of ring & pinion sets along with installation kits. You could also put an ad in the parts wanted section.
I think the Patricks set up is around 800$ for everything. Then someone to install it, unless you have the tools and know how. I know I don't, but wish I did.
Maybe find a used rear end and swap it out?
