0 members (),
108
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 202 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 202 | Greetings Stovebolters
Does anyone know where I can find new "side gears" and differential gears for a 53 3100 rear end?
Thanks in advance Walt Williams La Verkin, UT | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Might check with Patricks, he sells lots of ring & pinion sets along with installation kits. You could also put an ad in the parts wanted section. | | | | | Joined: Apr 2006 Posts: 136 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 136 | I think the Patricks set up is around 800$ for everything. Then someone to install it, unless you have the tools and know how. I know I don't, but wish I did. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Maybe find a used rear end and swap it out? | | |
