| | | Forums66 Topics128,091 Posts1,056,036 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#74435 03/08/2007 3:21 AM | Joined: Jul 2006 Posts: 187 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 187 | I can't tell without looking and measuring both at once but will a 66 C10 rear end directly bolt into a 63 C20? I need to swap ratios and am looking at this route or keeping the current rear and swapping ring & pinion. | | |
#74436 03/08/2007 3:30 AM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Should bolt right up, the trailing arms interchange btween the two. Brian | | |
#74437 03/08/2007 5:11 AM | Joined: Jul 2006 Posts: 187 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 187 | Thanks Brian, you always come through on this era truck. | | |
