0 members (),
47
0
Mod | | | Forums66 Topics128,050 Posts1,055,641 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 4 New Guy | | New Guy Joined: Nov 2009 Posts: 4 | Is there a secret to installing the plastic push-in pins, tried a blunt end screw driver and the end snapped off, any ideas??? | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I went back with the original alligator clips using a washer on the head end for extra holding power. I could not see how the plastic would work without drilling out the holes some. | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Z28.
I tried a touch of axle grease on the tips when I pushed mine in using a slightly rounded wooden dowel about 6-8" long. PITA.
