5 members (Bill Hanlon, 52Carl, Otto Skorzeny, SmalltownTRKGuy, 1 invisible), 80 guests, and 3 robots.
Topics128,094
Posts1,056,058
Members48,433
#744163 05/02/2011 7:45 PM
Good afternoon all. I'm having trouble with my 250. It was running well a week ago, now it won't start. It cranks, but won't fire. It has spark and plenty of gas. A few things that I noticed was that air is puffing out of the carburetor. I suspect the cam has jumped a tooth or two, but is that even possible with these engines? The ignition rotor does not point at the #1 terminal when the motor is at TDC. It is closer to the #4 terminal. Compression is all over the place from 30 psi to 80 psi. Is there anything else it could be besides the cam being out of time with the crank?
Riding in the Passing Lane
That sounds like the problem but it is rare on that engine. They dont use achain but the 250 comes out with a fibre cam gear. Take the valve cover off & check the location of the valves when at TDC. When you are at TDC the valves on #6 Or #1 should be overlapping. Like the exhaust closeing & the intake opening. If that is correct then your dist. has jumped time.
1972 Chevy c10 Cheyenne Super
Yeah, I remember that about the 250's. I forgot. Thatnks for reminding me. I will take the front cover off and have a look. I will report back. Thanks again!
The cam gear is aluminum. It's in perfect condition and in time. I will take the valve cover off tonight just to see if there is anything fishy. After that, I guess I should be preparing for a rebuild??? The motor smokes when warm and there is a good bit of blow by. I suspect the rings are bad and that's why I have low compression. That would definately make it not start, but it's weird that it was running a week ago. Any other suggestions?
Put the timing mark at zero, take the distributor cap off, turn the dizzy to line up rotor tip on #1. Should be easy to turn the dizzy cause I suspect your hold down bolt has loosened. I had the same problem. Timing kept changing till I figured out the clamp with the bolt going thru it was on wrong.
Thanks, I got it running. The ignition timing was off. I haven't a clue how that happened, but it's running good. Thanks for all the help.
