6 members (Oswald, farmallb, Stovebolt48, GrandpasJimmy, 2 invisible), 132 guests, and 2 robots.
Topics128,089
Posts1,055,988
Members48,430
#744215 05/03/2011 1:03 AM
Anybody know what the best grade of oil to use in the stock rear end on a 59 3800, and how much to put in??
panman #744301 05/03/2011 11:36 AM
sae. 85-90 is what i use in my rears.
51 ashton #744548 05/04/2011 4:51 AM
what about the transmission?
I'm most likely looking at filling both my rear end and transmission with synthetic when I get it all back together. Just curious if you guys are using the same weight in the 4 speed tranny as the rear end as well as what the collective thoughts are on synthetic.
aggie jon #744597 05/04/2011 12:43 PM
I run 85-90 in both. I believe I added some Lucas oil treatment to the tranny. Couldn't tell you if anything feels different or "smoother"
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
1924 Ford Model T Fordor
aggie jon #744862 05/05/2011 6:51 AM
sly Offline
As Workmaster says, 80/90 works for both. Fill till it starts to run out of the fill hole. If you go with synthetic, which will keep the heat down on the hot days and flow better on the cold ones, you will probably end up using a 75/90.
Moderated by  Dusty53
