4 members (Eisenholtz, baldeagle, NJC, Southerntruck), 165 guests, and 2 robots.
Topics128,037
Posts1,055,468
Members48,424
#744202 05/02/2011 11:51 PM
I picked up a radio for my 65 the other day and can't figure it out. How does the tuner or right side of the radio physically mount to the dash or does it. The threaded part of the tuner sits behind the dash opening. Am I missing something?
rossboss #744248 05/03/2011 3:22 AM
The tuner & potentiometer should have two jamb nuts on them. Remove the first one and make sure the bottom one is tight against the casing. Insert the radio from the back of the dash, through the factory openings and put the jamb nuts back on. There is also a factory brace, that attaches to the back of the unit and attaches to the factory dash speaker assembly.
rossboss #744369 05/03/2011 4:02 PM
The threads on the tuner or right side of the radio aren't going through the hole in trhe dash. There is a semi-cirular piece in the casting that butts up against the back of the dash but the threads don't make it through. Unless I'm missing somthing there is nothing to screw the jam nut to.
rossboss #744378 05/03/2011 4:24 PM
are you sure that it is the right radio.any pictures of the radio or your problem
ron
padresag #744386 05/03/2011 4:45 PM
sounds like you have a car radio, they used a recessed mounting cup on the tuner side IIRC.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
